Data logging using MS Excel/Word & RSView ME
I used this PRODUCT with great success, cost is around $350 USD. It logs serial data that would normally go to an alarm printer. Don't know if this is what you're looking for or not. But, you can set it up to have different colors for different key words, and play a .wav file to inform the operators. However, the data is stored in a standard text file, and not MS Word.
Ken,
Can u pls update the link given??
Hello, is it possible to log data (7 or 8 sensors) from TIA portal v15 to Microsoft access/ excel directly for a short period of time e.g.1 hr...
7,692
hello frnds.... i want to Data log in FTV SE using RS view log viewer ... as it is working in RS VIEW 32 application.... is it possible to data...
3,322
This might be a bit out of the box: I want to try an use a smart relay to gather data, specifically start and stop times, times in between...
1,790
I have a data logging application which logs four analog inputs at the rate of 10 hz. I created a pulsing bit at the plc and logs data at the...
1,924
Hello all. First post on the site and have a question about data logging. I am using Modicon Telemecanique pl7 Junior Plc with Schneider...
2,662
