Database (SQL) alarm logging with FTView SE
phuz
Jun 2008
Mohnton, PA
1,044
I have not used this aspect of FTView SE, so I am looking for some direction. I'm looking to add some alarms into a SQL database. Nothing jumps out at me, nor can I find any documentation on it. So I created a new data log model using an ODBC source pointed toward the SQL server, allowed it to create the necessary tables, and then added a few tags and set it up for data change only logging.
This can't be the best way to do this, is it?
Oh, how about under Tools -> HMI Tag Alarm Log Setup ?
It couldn't be more obvious. :)
I notice that the alarm tag description doesn't get entered into the DB. This is a bummer. I'm also seeing that it is not logging to SQL every 1 minute as I have specified. In fact, it only logged an alarm 3 times and hasn't logged anything since, no matter how many times I toggle the bit. If I go to Tools -> HMI Tag Alarm Log Viewer, they appear there, though.
Hello, Does anyone have experience managing the FactoryTalk alarm & events SQL database from outside of FactoryTalk? Essentially I'd have tag...
1,304
i am testing how to add a database in FTview site v7 or v8. i add new database under connection, i have connection to DB with using new user and...
2,780
Can anyone advise ? 1. I want to retrieve previous alarms and export alarms in excel file so that i can know alarms' date/time, alarm state...
6,676
Hi, We are doing a project in FactoryTalk View with Database connected to SQL via Connections available within the FactoryTalk View Project. Is...
1,599
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,314
