Retrieve and export alarms from FactoryTalk SE SQL server alarm history database
minaykha
Apr 2009
singapore
96
Can anyone advise ?
1. I want to retrieve previous alarms and export alarms in excel file so that i can know alarms' date/time, alarm state, etc..
I am using Factory Talk SE(ver.7) alarm log viewer and SQL server express(2008) as alarm data base.
2. I used Key up/down button in Alarm Log viewer display, but i could not make it work. Any suggestion ? Pls refer to attachment pix.
Set up an ODBC connection to your database.
In Excel you can connect to the database using ODBC to get data from any table you want. My Excel isn't in English (don't ask) but you should have a data tab and under that a selection for something like "other data sources." From there it's just fill in the blank. Pick the data source, provide the password, and pick the table(s) you want.
Good luck,
Yosi
Thank alot Yosi.
That is great, i could manage to import alarms in excel file from database.
But, there is no solution for my question no.2. Up/Dwn key function work in ME but not in SE.
we have lost the HMI Panel View source file (.apa) we do not have back either. we have only .PBA file. can some one help how to get .apa source...
1,147
We have many CISCO and STRATIX switches in our process network. The Stratix switches have AOPs that enables us to use our Rockwell PLCs to gather...
2,234
Hi, I started my journey with Micro820 and I have to read input status address 10001-10010 from one device via Modbus TCP, everything works fine...
1,196
I'm headed to my shop right now to try an experiment. I'm trying to find out if the PowerFlex 700s can swap control boards and successfully power...
2,575
Hi All, I am writing a piece of software for some research and would like to retrieve a running program from a PLC using python or some other...
1,997
