DataStore column Formatting PV Plus
nmk34
Apr 2019
texas
80
i have 4 tags that i am collecting data on in a log file. is there a formatting available to put each tag in a separate column instead of having the tags in one column ?
Can you give an example of how your .CSV file is getting formatted, versus what you want ?
By default, the DataStorePlus has one Row for every log event, which includes an entry for each of the possible 50 Analog and 50 String values in its own column.
In my view, that is "one column per tag".
An excerpt from logging hour/minute/second on a 10 second period:
Code:
;RowNum,Alg 1,Alg 2,Alg 3,Alg 4
1,15,4,24,0
2,15,4,32,0
3,15,4,43,0
4,15,4,52,0
5,15,5,3,0
I have come to the conclusion that ME datastore plus is not very reliable at doing what it is supposed to do. Please prove me wrong so that I can...
2,324
I used theautomationblog step by step to get this datastore to change the screen back to the original initial screen. I keep getting "NO SCREEN...
5,264
i need help in getting Datastor plus to create the log file in the location as configure the activex object. i have an existing project that i...
3,089
I have set up datastore plus, as per https://theautomationblog.com/datastore-plus-step-by-step-setup-in-factorytalk-viewstudio/ Using a PVP 7...
1,662
So I am having a problem collecting data from my PVP7, I am currently testing via two ways of fie collection. I am both using an physical USB, and...
1,370
