DB pointer ?
Berra
Mar 2007
Sweden
137
hi,
Someone you can give me som tip?
I have 10 engines that I have created in a UDT, and each engine has a starting address. Engine 1 has the starting address 0. but the speed variable of the engine has the address 6.0 how can i make the pointer point to that address ?
This dosen´t seems to work:
OPN "motor_lista"
l # pointers
SLW 4
lar1
L 50
t dBW. [AR1, P # 6.0]
/ Thomas
You do not show the processing for the "pointers" variable.
Copy the relevant blocks to a library and post the archived library. We can then see the udt layout etc.
Ok, here is the File of udt.
i saw have type the wrong adress for the speed variable it should be address 4.0 in udt.
Code:
      L     5                           //for test
      T     #iMotorNumber
      L     6                           //constant for UDT
      T     #iSizeOfMotorUDTInBytes
      OPN   DB     3
      L     #iMotorNumber               //make zero based
      +     -1
      L     #iSizeOfMotorUDTInBytes
      *D
      SLD   3                           //convert to pointer format
      LAR1
      L     50
      T     DBW [AR1,P#4.0]             //speed setpoint
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
544
I am trying to access the value of a pointer via OPC UA in Codesys. I can share it directly and in a struct but I cant access the value of it when...
1,621
Why does my deconstruction of the input pointer only work with its own instance DB not inside the multi instance FB...See .doc The pointer at the...
2,355
Hi All, in many library function of TiaPortal some data must be write using the pointer format........ eg.: P#DB90.DBX0.0 WORD 10 is it...
2,820
I have a very strange issue and I cannot figure out why it is not working. I read input of type pointer and store it to local temp type any. I...
1,934
