DC drive card - OT
Aug 2002
Manchester
527
Hi
I've got a 90V 0.55KW DC permanent magnet motor whose speed I need to vary with an analogue signal. Anyone know of a manufacturer of a unit that might perform this.
Thanks and apologies for OT.
pp
Many 90VDC speed controls will accept a 0-10V analog signal in place of the potentiometer. What brand/model speed control are you currently using?
beerchug
-Eric
If you are using some external 0-10VDC signal as a reference, such as from another drive, or piece of equipment, it is strongly advised that you put a signal isolator between the reference and the KB drive.
They make isolators for all of their drives.
We have a lot of the Seco DC Drives (Bronco II 160 Series) controling our 0-90 DC motors.
Bob O.
As rdrast suggested, a signal isolator is recommended. KB Electronics signal isolators are on THIS page.
Let me guess, you're using a KBIC-120 control... :D
beerchug
-Eric
I'll go a little stronger on this. A signal isolator is required unless your analog signal source has built-in isolation. One of the ways KB keeps their drive costs down is how they derive their logic power. They use a resistor based voltage splitter off the main AC supply and rectify that. This means the whole drive floats at the AC supply level. I fried a few non-isolated analog output points before I looked at the drive schematic and came across that morsel.
That being said, the KB drives are a very capable product for the price. They don't have great bandwidth but they will give you reasonable speed control for a reasonable price.
Keith
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
511
Hi Experts! I'm trying to control a solenoid valve (don't have part number, but I've been told its a 24V DC 30 watt coil) with a PLC output card...
6,630
Cheap PLC that can read Data from its SD card or USB Flash Drive? I'm looking for something in the price range of a Productivity 1000 ($180 for...
4,643
Hi Experts, i am working on Simovert Master drive in which CUVC and T-100 (technology card 6SE7090-0XXB7-0BB0) card is installed. I have drives...
3,317
We plan on having a stationary panel with a PLC , 3 Powerflex 527 drives , with the incremental encoder from the motor to the encoder option card...
3,469
