dde Link VBA instruction
KEN_KACEL
Nov 2002
NORTH COUNTRY
162
I resurrected a debugging tool for a job I did 3 years ago.
I have activeX buttons with some VBA code to select some PLC registers:
RSIchan = DDEInitiate("RSLINX", "FISH_FEED_X6")
The buuton keeps hanging up on this command.
What would of changed? I am usig RSLinx (CPR 9).
Would this have anything to do with it?
I have additional excell sheets for other projects that may not work?
Try RSIchan = Application.DDEInitiate("RSLINX", "FISH_FEED_X6")
Make sure that "FISH_FEED_X6" is defined in RSLinx as a DDE Topic.
Tried : RSIchan = Application.DDEInitiate("RSLINX","FISH_FEED_X6")
No go...
There is an error message popup:
can't compile error
can't find library or project
Do you have a topic in RSLinx defined as FISH_FEED_X6?
Another thought, what version of RSLinx are you using?
What other software is involved?
I know that Micro$oft tends to change their Office software regularly. Is it a different version of Office? What about the security settings? Are macros possibly disabled?
Dear Friends; I copy the link of Tag value and paste it as a link in Excel but Cell shows #REF The images are attached where i am wrong...
780
Folks, I have a excel linking question that I have not been able to solve or find an answer to via googling. I want to assign a spreadsheet...
1,891
Hi Guys, I want to query Unsigned DWORD in Top Server from Intouch but intouch only supports Signed Integer or real. When I use Integer or real...
2,361
I am trying to run an excel file in 2003 which has DDE links and push buttons. I get an error when running one of my push buttons . It errors on...
5,615
Hi All, I have been doing MS Excel worksheets collecting data from ML1400 via RSLinx OPC / DDE Topic. I have made it work but when I am doing new...
3,433
