Dead Backup Battery on S7-300 wtih CP342-5 PROFIBUS
joeyd11ph
Aug 2009
Qatar
Hi
Anybody here can teach me how to reload te user program after backup battery failure using only COM PROFIBUS V3.3 TOOLS?
Can I use memory card from other similar setup to reload the configuration data and user program?
MY SETUP ARE:
S7-300 > CPU 315-2DP (6ES7 315-3Fx-0AB0)
PROFIBUS CP342-5 (3425DA02-0XE0)
ASi CP343-2 (343-2AH00-0XA0)
MEMORY CARD MC951/128KB/5V FLASH
(6ES7951-0KG00-0AA0)
PC > CP5613 DP BASE (6GK1561-3AA00)
SOFTWARE ARE:
SIMATIC NET INDUSTRIAL COMMUNICATION PC/WINDOWS 05/2000 S79220-A5406-F000-01
COMPROFIBUS V3.3
COML7 V2.12
OPC SERVER
SETTING PG/PC
WINCC V5.1 S79220-A6045-F000-01
In the above setup, where can i find the user program? What file extention they use/format?
tHANKS
Joey
Had a callout today, machine I built in 2019 (Feb) with a 1769-L16ER-BB1b. Major fault, local IO module (there is no point attached). Reset major...
2,255
I've had a laptop die on me, with a win7 install. Bad news is, S5K had borrowed a license from a dongle onto it, then it died. Have installed S5K...
2,278
Hi all! I have this old Siemens Simatic op7 panel I need to rescue. At boot nothing appears on lcd, backligth and all led's are on. Does not...
790
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,275
Greetings, It it permissible for electrical components to be installed on the inside of a swing-out "Dead Panel". This is the swing-out panel...
1,431
