Dead DL06
allscott
Jul 2004
1,332
I don't deal with AD PLC's much. I have a DL06 that has power going to it but is dead as a doornail. Is there a fuse or anything internal to these that could blow, or is she toast.
Renove any connections to the 24 DC power out on the unit, any add-in cards, any communication cables and all input and output wires. Then re-test. If you get a good indication then add stuff back in one thing at a time.
Though if you've already done this then you are probably toast. There's no user replacable fuse inside.
Had a callout today, machine I built in 2019 (Feb) with a 1769-L16ER-BB1b. Major fault, local IO module (there is no point attached). Reset major...
2,266
I've had a laptop die on me, with a win7 install. Bad news is, S5K had borrowed a license from a dongle onto it, then it died. Have installed S5K...
2,297
Hi all! I have this old Siemens Simatic op7 panel I need to rescue. At boot nothing appears on lcd, backligth and all led's are on. Does not...
791
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,285
Greetings, It it permissible for electrical components to be installed on the inside of a swing-out "Dead Panel". This is the swing-out panel...
1,433
