Dead output relays
MMeduna
Jan 2013
Wahoo Ne.
HELP Have a semens S5 100. We had a semens midi master inverter throw an over amp alarm code. But when it did this the output relay units went dead. The plc is still working. The digital inputs are still lighting up and register when the control power button is activated but the cycle start button lights momentarily. Went through the whole semantics . All switches and circuits test out ok. Tried replacing outputs but nuthing. Did something in the plc fry? Don't have a replacement plc yet but would hate order one if don't need to. Ended up rewiring the machine to bypass the plc just to get the machine online again but would rather have it right
on the card is a fuse, repair it, hopefully that was all, otherwise the output is fried and needs repair by siemens or other (unis)
Had a callout today, machine I built in 2019 (Feb) with a 1769-L16ER-BB1b. Major fault, local IO module (there is no point attached). Reset major...
2,263
I've had a laptop die on me, with a win7 install. Bad news is, S5K had borrowed a license from a dongle onto it, then it died. Have installed S5K...
2,286
Hi all! I have this old Siemens Simatic op7 panel I need to rescue. At boot nothing appears on lcd, backligth and all led's are on. Does not...
791
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,284
Greetings, It it permissible for electrical components to be installed on the inside of a swing-out "Dead Panel". This is the swing-out panel...
1,433
