Debounce
Just checking.... Debouncing means not reading from a momentary flicker, right? If so, this should do it. It's a fairly standard way to take a straight input and turn it into a delay on/delay off setup. Adjusting T4:1 controls how long the input needs to change before the input affects the circuit, and t4:2 keeps it on for as long as necessary. Instead of using the input, just use T4:1/DN
I have to say you are correct!!! One of the reason for a debounce is to get rid of relay chatter, I use alot of debounces to control outputs involved with heat control. Operators hate hearing a constant on off on off then hold in. If you have a input that see's a constant input to control an output(or anything else) that can vary up and down quickly, add a little debounce to the control system, you'll save yourself a lot of headaches from the operators saying it just doesn't sound right.
Excellant! I added the photo eye that I was debouncing to the seal in so that the timers would reset and it works great. Thanks.
Hi all. Is this the simplest way to debounce inputs in Ladder (there are 2 points being debounced here)? The TOF drives the tag. I'm expecting...
500
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
691
Hi Group I have an on/off type steam valve which is set to maintain temperature in a vessel. If the PV drops below setpoint, the valve is...
1,694
Working with a huge PLC 5 program that does not have much memory left in the processor and it has about 600 alarms in all and about 270 of them...
4,117
Ok, I'm using Rockwell's PlantPax add on instructions. In the package there is a Digital-In function that has a "Debounce" option, which doesn't...
6,599
