deciding the location of the camera and lighting
AMAZINGAHMED
Jul 2005
Cairo
101
Hi there,
I have a VS721 camera and a Nerlite dome lighting for inspection of pills (medicine) inside blisters (before applying foil cover). I need to inspect the healthiness (completeness and presence) of those pills.
I have a 35mm lens.
I just need now to locate where should i put the camera and lighting to obtaing a sharp image and an appropriate Field Of View (FOV)
Is there any formula to link the FOV, focal length and diatance for the camera and light?
Thanx
This is based off of DVT but maybe it will get you started.
I have worked with the Monster dome and I always place the camera and dome perpendicular to what I was inspecting.
Hope this helps.
Edit...I added another file to calculate exposure time if your interested.
I've heard someone saying I should put as many programs/routines in the continuous task. I also heard others saying use as little continuous task...
18
6,474
Hi, In the late time, we started to work with Siemens. And we are making a lot of quotations with it, specially systems based on the IM151-8, and...
2,392
Hi guys, I need some help deciding on what PLC should I use. It's for controling some pumps and stuff. I've worked several times with PLCs, but...
1,879
1,900
I have a old program that I am coverting. The old program uses a personal computer, a serial scale (Meddler-Toledo) and a Opto controller for...
4,895
