Decimal point in Compact Logix 1769 L32 E processor
paul_36
Sep 2010
Trinidad
Dear All,
I am using 1769 L32 Processor. I need decimal points or floating point application in my mathematical instructions. I am not able to figure that, can someone help?
Regards,
Paul:unsure:
You need to have a result that is a data type REAL. Also, if you enter direct values with decimal points in them they are considered floating point numbers (REALs).
Keith
When you create a tag you must declare it's properties, use REAL as it's type. Nice that you can create a tag that is "undifined" and then later assign a type. INT, DINT, REAL ect... If using the tag editor you can enter a new tag and the default data type is usually DINT, before you hit the enter key click on the type column and enter REAL.
Logix5000 Converted DINT to REAL. Now...How to clear the decimal point? Thanks in advance
1,867
Good Afternoon , I have a number like .025690034 and I'm trying to keep a plate gap of .025 that has a motor driving it. This 3 phase motor...
3,696
Hi my problem may have a simple solution but i cant work it out. I need to use the Divide function but it wont let me use a decimal point in...
1,748
Example MMI input is 18.9787 to tag MMI_real[1] I want to move the 18 to a decimal number in tag Calibration_MS I want to move the 9787 to...
2,200
Ladies & Gent's, I am reading a floating point number from a Seimens RWF40 controller(PV) modbus address 30000 IEEE_754 format. I want to...
2,726
