Define initial graphic (display) on factory talk 5.10
Saavedra
Jun 2015
Tijuana
24
Good evening
I know these might seem trivial, but how do you define an initial display on FT 5.10? I made a display named ¨[MAIN]¨ just like in factorytalk 7.0, but in this one the main is not defined by default.
Thank you.
In the project tree on the left, under system, there is a start-up option.
Open this and you will see initial graphic option. Put whatever graphic you need in here.
Cheers
Mark
hello dear forum, About DELTA DIAView SCADA I defined a variable in Timescript VBscript I want access this variable from within a window For...
589
Hello PLCS.Net! I have the EDS Hardware Installation Tool installed on my PC. When I try to install a file, It says it's successful, the...
2,043
Hi all, I want access a Mitsubishi PLC Q series to SMC. I am using Archestra DASMTEthernet as my server in SMC to connect with PLC. After I...
1,427
Hi, I was wondering if anybody can help me with this issue. I have *.cab backup created from a lower version (Dev Studio 2012R2) and I loaded it...
5,379
Hi Guys, I searched throughout the forums but didnt find any information on this topic. I currently have an application that relies on macros...
1,619
