Deleting and renaming a file on panelview
reecetr
Feb 2005
Have a Panelview with five(5) user programs loaded. Want to delete the number five program and rename another program to move into its place. Can this be done? I am a novice at best on panelview. Thanks for any help
What's the model # and Revision?
--I wasn't even aware that PV can store more than one program except on the Flash card...
I'm guessing that he means that it has a flash card. Assuming that, shut down power, remove the flash card, take it to a compatible computer with a PCMCIA slot and compatible driver, then do all your file manipulation there. After you are done, put it back into the Panelview and turn power back on.
You can remove the memory card without shutting down power, goto the configuration mode, at the config screen select memory card and then select disconnect card, when its safe to remove it take it out and then take to a compatible computer as bernie stated.
Hi, I have a s7-1200 at home that went into "CPU error: Serious firmware exception". After a power cycle it was OK again, but all retained data...
872
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,079
Hello EtherCAT gurus. Is it possible to delete the EtherCAT Stack Code information from an EtherCAT device using the available Windows tools...
1,290
Hello: Richard here, new to the group. We are learning Studio 5000 in my advance PLC class at school, but greatly limited by not being able to...
1,792
All of these processes are taking all day to run. When doing the same operation in a stand alone intouch application it only take a few minutes to...
1,619
