Deleting unused tags in Logix 5000
dbh6
Jan 2013
Central, NJ
552
Im using a control logix based PLC, i made a lot of changes to my program and their are a lot of tags that im not going to end up using. Is their a way to either filter out all unused tags in your logic and delete them, rather than going to that specific tag in your tag browser and hitting delete??
How you filter them differs a little by version.
I'm looking at a version 16 program: Go to the tag view, make sure you are on the edit tab. You will see a button that says "Show". Click it, where you see "Filter On" select unused.
Other versions are slightly different, but offer the same thing. What version are you using?
@dmroeder, i figured it had something to do with the version numbers, i have two programs one is version 16.21 and the other is 20.11, i followed what you said and was able to find all the unused tags for the version for both version. Thanks
All of these processes are taking all day to run. When doing the same operation in a stand alone intouch application it only take a few minutes to...
1,607
I am currently working on a project where IO is not being used but previously was used in the field. In logix for example I have a tag where we...
6,988
Hi I am using Wonderware's InTouch 7.11. I created a tag and used it in one of the windows. But after some time I decided to remove the...
19,979
Hi, I have a s7-1200 at home that went into "CPU error: Serious firmware exception". After a power cycle it was OK again, but all retained data...
841
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,045
