Delta AH500 EN PLC reading from XML file
Fatlum Telaku
May 2022
Kosovo
Hi everyone,
I have an issue, how is it possible to read data from an XML file with Delta PLC?
In fact, I have another device (ElectroCell from PolyTouch) which I have to make communicate with my PLC and HMI. The physical infrastructure provided by that device is EtherNet but I don't know precisely which protocol is used if it is standard Modbus or something else.
Another thing is that I can set to this device static IP's in the same subnet with my PLC and HMI and I also can access this device online via HTTP page with defined IPs and from there I can see the XML file. But I don't know yet if is it possible to set a real-time communication between these devices.
What I found till now is that this series of Delta PLC have explained how to configure TCP & UDP sockets and I have also tried that but it still didn't work in my case.
Thank you in advance!
As XML is not a protocol it is language/format for storing, transmitting, and reconstructing data. It can be done, but it could require lot of programming code depending of what you need to acquire from that device.
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,041
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
44
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
119
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
154
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
139
