Delta DVP SA Communication
rohit_plc
Jun 2013
delhi
81
i want to connect delta dvp sa plc to pc having scada running on it at a distance of about 100meter. i think rs232 will not be work on that distance, how i can do that..??
DVP SA has RS485 port that talks MODBUS ASCII/RTU. You would have to use RS232/485 converter on the PC side.
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,343
i have dvp 14ss2 plc and kgk inkjet printer .how to send data via rs232 com port,and if any sample program available please send .
2,068
Good evening everyone. I've set up a network for an equipment I'm integrating. however as a way of saving up space/money, I tried to make a...
3,061
Hello All, can anybody help with the Sample program of the Delta PLC and SCADA with modbus communication through RS485 port. Regards Amit
18
17,163
Hi all, I am using Delta DVP-SC Series PLC and LS iG5A VFD. I want to vary the VFD freq. with the help of PLC, using Modbus. Please help me how...
4,776
