Delta DVP28SV11 PID configuration
Redbase
Jan 2015
Perth
Hello All
I am trying to configure a delta PLC with a PID loop in order to maintain tension in a cable. The tension sensor is an AB encoder and tension would be maintained with a servo, ASD-A2 series, operating in step direction. Understand that the PID is not the only possible solution so any alternatives welcomed.
For the DPID configuration API; setpoint is zero, the high speed counter C251 from the encoder (2 phase) is stored in a data register so it can be accessed as present value and lastly the configuration registers, using DMOV, represent a 100ms sample time and the largest allowable range for each of the P I D parameters. I have played with changing the individual PID gains without any resulting change in the output value.
The Delta application instructions are relatively clear however I am chasing a working example or some pointers as to what could be a miss.
Thanks in adv, Greg
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
71
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
151
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
174
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
148
How i Can connect Delta plc, with Beckoff remote IO cards?
192
