Delta plc no online with usb to rs485
Kataeb
Jan 2007
www.livelovelebanon.com
636
Have you made a connection before using this computer?
What is the operating system?
Under the "Device Manager" in windows, do you see the com port associated with the usb device?
You want to test each component to determine the exact problem. Maybe the device is defective.
Regards,
We did not have much luck with the CH340 and Delta PLC's so we ended up using a PL2303 chip set in the cable we sell, you may want to look for another adapter
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
50
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
121
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
154
How i Can connect Delta plc, with Beckoff remote IO cards?
185
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
290
