delta Rs485 communication
muds
Apr 2014
karachi
71
hi all,,
i am trying to attached my HMI DOP-B3e with plc delta es2,, but problem is that hmi is showing communication error 3..
i provided link 2 RS485 communicatioin in DOPsoft programme,, but not know how i confiqure HMI in WPLsoft,,
thanks in advance
http://www.delta.com.tw/product/em/control/touch_hmi/download/manual/DOP-HMI_connection_en.pdf
The meaning of Communication Error Message:
1) Word Device:
The Device Name and Address Value will display. For example, if using CIO, H, A, D, E, T, C, W, EM, IR, DR, TK, it will show CIOn, Hn, An, Dn, Em.n, Tn, Cn, Wn, EMn, IRn, DRn, TKn respectively. “n” is the Address Value.
2) Bit Device:
The Device Name and Word Address Value will display, but the Bit Address Value will not. For example, if using CIO, H, A, D, E, T, C, W, EM, IR, DR, TK, it will show CIOBn, HBn, ABn, DBn, EBm.n, TBn, CBn, WBn, EMBn, IRBn, DRBn, TKBn respectively. “n” is the Word Address Value.
For configuration try this link:
https://deltautomation.wordpress.com/tag/wplsoft/
Regards,
Hello Everyone, I am looking for communication with delta PLC and barcode scanner over RS485 Please help.. The ladder program will be helpful...
1,882
how can i communicate delta bop 3e hmi through com2 delta es2(rs-485),
2,143
Kindly, we are trying the USB-485 (USB TO RS 485 converter) to access online, a Delta Plc SS2 through its serial port. But, we are getting an...
1,943
Hi All. Hope someone can help me. I am using a Delta PLC DVP12SE Network Module as a master which is connected via COM2 to 4 remote analogue...
3,907
Hello all, I am using a Delta inverter, VFD40WL21A on Modbus with a PLC. We are using the minimum communication parameters like RUN/ STOP...
8,602
