Deploying An AdvancedHMI Project
gclshortt
Dec 2014
Ontario
3,217
Here is our latest post on deploying an AdvancedHMI project on the industrial floor.
Here are a few thing we cover:
Hardware
- Computer
- USP - uninterrruptable power supply
Software
- Turn Off windows update
- Security - Set permissions - Limit internet use
- AdvancedHMI - remove ControlBox, Miximize Screen Size, Topmost property
Here is part of the post...
Deploying an AdvancedHMI project on the industrial floor sounds like an easy task, but there are a few things that you should consider. The HMI (Human Machine Interface) user interface will run on a computer. The industrial environment is one in which temperature, dust, electrical noise, etc. are always present. This can also be combined with workers wanting to play with the new computer. We will look briefly at the hardware and software items that will make your install more reliable and user friendly in the field.
Read the rest of the post...
Let me know what you think.
Thank you,
An additional tip:
On the PC that will run AdvancedHMI, click the start button and type CMD to find the Command Prompt. Right Click on the command prompt and select Run As Administrator
Once the Command Prompt opens, type the following:
bcdedit /set {current} bootstatuspolicy ignoreallfailures
This will prevent problematic startup when the PC is not shut down properly as often happens in the industrial environment.
Thanks Archie for the tip on disabling the windows error recovery on startup.
The AdvancedHMI software is a great product!
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
133
I restore a galaxy in another machine via the cab backup, but when I deploy the project in the new station it seems that the text object and some...
1,002
Hi all , im having some troubles when deploying a managed app. when deploying it gives me the following errors: warning: winplatform_001...
17,424
Hello everyone, I'm having some trouble deploying one of my nodes. Situation: A Server is working with 4 clients. What i'm trying to do is add...
3,824
Hi there everyone, So first, i'm new around here, so thanks that a site like that exist :P Now, i'm a new user of archestra IDE (i've worked...
15,427
