Design a Six Step Sequence with at least one timer and one counter
addbotz24
Aug 2016
Cebu City
can you help me with this one guys using fluid sim. This is for my bring home exam. providing a problem description, schematic diagram(system),pneumatic diagram, electrical control diagram and equipment list. We only have 2 single solenoids and one double solenoid in our laboratory. Pls help :geek::geek:
Attached is a RSLogix Pro Simulator program for a 6 step output. It resets itself a few seconds after the last sequence. Solenoids could be connected to each output, but I just used indicator lights.
@ Ronnie Sullivan,
Please review rule #1 posted under the New Here Please read this important info button.
After you do that please study the differences between pneumatic and plc type control. Also,
please note that what i posted is only a slightly modified program of one that I posted nearly two years ago called "Eight lights in sequence". Both are only teaching examples and are not to be used in a real application which is why I used a "Simulator" type program.
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
I've run into a non-plc issue that is proving hard to solve. I'm designing a mechanical device that has a base/foundation that must satisfy the...
401
I’m currently starting a brand new design with a compactLogix controller and a panel view 700. I’ve completed similar projects from start to...
1,244
What's a good place to start for learning electrical design? I am always the end user so I can follow along machine schematics, etc. but I want to...
3,909
Dear, I am wanted to design the marble cutter machine on HMI. The issue is how to show the movement of round blade reverse and forward...
925
