Design guidelines needed
jcp
Feb 2010
Multan
369
Hi Friends;
Hope all are fine. I want to design a ESD system of compressor station. I am confusing to select the PLC which i used.
I visist the market i found AB SLC100 and S5 plc but software required to programme and communicate with laptop is not available.
I require 15 inputs and 6 outputs. Voltage level is 24 VDC both input and output.
Please guide me which i use and able to communicate with it?
Please suggest me the Cheapest one.
Compressor station for what - compressed air flammable gases, cryogenic all have differing criteria and safety concerns.
Buy cheap - well you get what you pay for - OR - marry in haste repent at leisure.
Low initial cost seems good but I think you should consider
1. Life cycle cost
2. Local support
3. Will the low cost outfit be around in 10 years and still support what you bought?
Think I would allow for a few more inputs and outputs - there is always six months later "if we had just thought of this ,,,,,,,,,, and done that we would be better off"
Dan Bentler
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
170
I've run into a non-plc issue that is proving hard to solve. I'm designing a mechanical device that has a base/foundation that must satisfy the...
407
I’m currently starting a brand new design with a compactLogix controller and a panel view 700. I’ve completed similar projects from start to...
1,252
What's a good place to start for learning electrical design? I am always the end user so I can follow along machine schematics, etc. but I want to...
3,946
Dear, I am wanted to design the marble cutter machine on HMI. The issue is how to show the movement of round blade reverse and forward...
931
