Desktop PanelView Plus Testing Enclosure / Stand
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone!
I need to build / fabricate a stand that I will use at my desk.
The stand will hold a PanelView Plus 6 1000, PanelView 7 1000 and a smaller HMI, 4.3 inch.
I am considering different materials, plastic, wood (painted) or metal, but not sure which way to go.
I was wondering if anyone else here has undertaken a similar task, and if you did, what did you end up with?
I would basically like to have the HMI at 90 or a slight slope to avoid glare.
It doesn't need to have any Nema rating, as this is only for development and testing on my desk.
This is to avoid having to lean the HMI up against something and having it slide around when you are pushing on it.
Hoping for light and cheap.
I would be building this for myself, by myself.
Best regards,
Paul
This is a test stand on loan from my local AB rep. It is a simple bent-metal stand with a cut-out for a PanelView and a 24VDC power supply in the back.
As above, but I just got the guys in the workshop to make a cut out in some ally and bent the bottom 150mm to make the standy bit.
Red Lion has a nice cardboard stand built into the packaging.............
Thanks, didn't know that. Is there a toy in the box as well? Just joking.
I used to have that on my desk, I just cut out a hole in the box that the PanelView came in, but management and customers have zero sense of humor.
Is "standy bit" a technical term? :ROFLMAO:
FYI, "ally" probably refers to "aluminium" (or "aluminum" for all you 'merican folk :) )
Hi, I am setting up a technical manual display page on a PANELVIEW PLUS 1250 HMI, and the page references .pdf files held on an SD card on the...
1,664
Hi, The model for this HMI is 2711P-T10C22D9P. In the run time file setting I select panelview plus 7 10". When the HMI start, it will go though...
2,156
Hi everyone, I am new to this forum but I've been directed here a few times while troubleshooting in the past so I figured I would give it a...
4,752
Hi, I try to control a PannelView Plus 1000 with my computer, but when I use Remote Control Desktop Connection with the IP adress of the...
3,283
Good afternoon all, hope yall are well. Is there any program available which allows me to remote in on a client's laptop, but run the programs on...
1,421
