Desktop PC with a Serial Port?
Jul 2007
Kiruna
600
Hi there,
Is it possible to purchase a desktop PC with a Serial port these days?
I have an old Citect SCADA system I need to install on a PC which uses Modbus comms to a Modicon Quantum PLC.
Hi there,
Have you check ebay? the last desktops I bought did have serial ports they were Dell's
I would buy a regular PC and insert a pci express serial card (if it hasnt one onboard).
We replaced 2 years ago a PC with onboard parallel port with a new one,
adding a pci express parallel port (which had also a serial port) and it worked like a charm.
Funny problems that some people have... some are looking for serial ports, others find parallel ports in half of the computers running the SCADA system on site. LOL
In my experience it is usually the computer that dies first. If there is a PLC on site that uses serial ports for communication (SCADA or HMI on PC) then you have no choice other than get a new pc with an onboard or added serial port. Onboard is very rare these days, so our usual recipe is as indicated by crawler009.
We have a lot of older systems out there with clients that use serial communication. So we still keep a stock of PCI express serial cards to add to new PC's if a client asks for it. We see more problems with serial communication in recent years. Serial communication in newer systems does not seem to work as well as it used to do on the older systems. I do not know for sure if the root cause for this is in hardware, driver or Windows OS changes.
One of my clients regularly buys brand new Dell computers with serial ports. They don't buy them off the shelf, of course, they configure them online and order them that way, but you can easily still get them.
Please join us in 2018
Hi there,
I understand you are trying to maintain your "Old Citect SCADA system".
My suggestion: As opposed to trying to down shirt and adapt to obsolete communications strategies. (spending new money to stay in the past)
Why not aggressively update the SCADA system with products that can be supported with hardware and software that would be understood by a new employee that just came from an up to date learning institution?
My $0.02
Plastic
Support for obsolete equipment.
Plastic
There are a lot of companies that have no interest in updating their equipment.
MorphuisOGrady
My suggestion is to buy an older refurbished laptop. You can find them on Ebay for decent prices, under $200. I keep a couple around running XP3 and Window 7 to support older hardware. Most if not all have serial ports.
Regards,
Sydney
Google min-itx
they do fanless pc's, the jetway range comes with a serial port.
I also have several Citect pc's using usb serial adaptors which work reliably
Get a Moxa USB to Serial converter. It is the best serial converter in the industry, it allowed me to connect to every kind of serial device when I was setting up Power Monitoring.
Good afternoon all, hope yall are well. Is there any program available which allows me to remote in on a client's laptop, but run the programs on...
1,421
For my first time, I put a copy of Studio 5000 and Factory Talk Activation Manager on my customer's machine (On-logic Windows PC), then use remote...
2,497
I am hoping someone here can help me out with Remote Desktop Connection Manager. On my clients an on my ThinManager server my screens size fine...
698
Hello: Did a project some months ago for a customer. It is a Windows 10 application running on an industrial PC which is not connected to the...
17
3,568
Can anyone recommend a desktop lock application that would be good for industrial use? I know the FlexLock utility is shipped inside DeltaV and...
1,205
