Desktop used as an HMI programming help
Gtemplet
Jun 2019
Il
Good afternoon. I just recently did my first Panelview Plus 1000 programming using Factory Talk View Studio ME. With a little bit of trial and a whole lot of error I eventually added a push button, numerical display, numerical input, and some text. This was all done locally at the machine. Now I have to add the same thing at the operators remote desktop. The computer already has HMI capability, so I’m not starting from scratch. The Remote Desktop has Factory Talk View Studio ME version 5.00.00 (CPR9) on it. My problem is when I go to Transfer Utility to upload the program I don’t know what ‘source’ to use. At the bottom of the screen where I ‘select source terminal’ I chose the computer at the top of the tree and it told me invalid source. I can see all the PLCs and PVs on the network, and I was able to upload the PV I just programmed. How do I find my source/destination so I can upload/download? Thanks for looking and appreciate any help.
The Transfer Utility is for upload/download the runtime program to PanelView terminals only.
To run the HMI application on a operator PC you would have to use "FactoryTalk View ME Station" to run your FTV application.
The Runtime file should be located on the PC in Documents or Public Documents depending on Win. Version. > RSView Enterprise > ME > Runtime. The file will have a (.mer) extension.
Under Application Manager you can convert the .mer extension back to a development application in case the two files are different. If both are the same then you only need to copy the (.mer) into the Runtime folder in the path shown above.
Just be sure to keep a copy of the original until you confirm they are the same file. They could be set up with different resolutions.
Thank you gentlemen. cwal61 and KuulKuum excellent info. I now have questions about adding tags. Yesterday I finally got to try my new found info. I added an analog display, and created a new tag for the display and saved. I then created runtime application, loaded my new application. My display was there with only ****s and a message popped up ‘F8:166 to small or missing’. Instantly I realized I put the wrong Float in, I needed F8:127. Easy enough, so I thought, I went back into Factory Talk View, clicked on my analog display went to properties>connections>went to incorrect tag>edit tag (fixed tag address) then saved. This fixed the problem I now had the correct value in my display. Today when I opened my ‘project’ to do more changes the tag I entered incorrectly and fixed was back to the incorrect address. I changed back to correct address and added a new tag for another analog display and saved. Created and loaded project, worked fine. I then exited my saved project and reopened. Checked the tag list and the first tag I created was wrong again and the new tag was gone. I deleted my project and created a new one from the currently working program. Checked tag list and again wrong and gone. Any ideas??? Thanks for looking, sorry for how long this is.
Good afternoon all, hope yall are well. Is there any program available which allows me to remote in on a client's laptop, but run the programs on...
1,416
For my first time, I put a copy of Studio 5000 and Factory Talk Activation Manager on my customer's machine (On-logic Windows PC), then use remote...
2,495
I am hoping someone here can help me out with Remote Desktop Connection Manager. On my clients an on my ThinManager server my screens size fine...
698
Hello: Did a project some months ago for a customer. It is a Windows 10 application running on an industrial PC which is not connected to the...
17
3,563
Can anyone recommend a desktop lock application that would be good for industrial use? I know the FlexLock utility is shipped inside DeltaV and...
1,201
