Desoutter Torque Controller
Gadelric
Nov 2018
Midwest
137
Quick question,
I have a Desoutter cvic 2 controller that I was asked to make it mobile.
It is currently mounted to a huge station on wheels, that is just too big.
We would like to mount this to a smaller station that we can wheel around, and just plug it into a 115 v AC outlet.
This current set up has a PLC and low voltage.
Does anyone here know if we can set this thing up without a PLC/low voltage.
I don't need to record torque data or anything, just need to put some screws into foam, and this tool works the best for what they want to do, I just gotta make it work.
Mounting a small enclosure to house a small PS can be done, I just don't want to if I don't have to.
No reply from the manufacture,yet, so I thought maybe I could get lucky here.
Gad.
Found my answer,
These controllers can supply their own 24v dc, there is a jumper that has to be put in to jump 24vdc to the enable, and then they become stand alone.
Good day All, We are using a Desoutter CVIL II Controller for a project. It is currently connected from the RS232 Port of the Contrroller to a...
2,773
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
91
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
274
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
446
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
529
