desperately need simple sample programs or exercises for Step7 Professional
Just out of interest, is there a way of searching the library of SFC's in order to try and find one that's suitable for your needs or is it just a case of trawling through them all and reading the help file for each one.
I've used the trawl and try method.
You can open a Data block as a DB or DI in your code irrespective of whether the Data Block was created as a DB or as a DI
So it doesn't matter if I open a shared DB as a instance DB and vice versa?
Code:
      OPN   DI [#DB_Number]
      L     DIW    0
      T     MW    10
      OPN   DB [#DB_Number]
      L     DBW    0
      T     MW    10
Best pratice??
L DBLG gets the length of the data block opened with OPN DBxx
L DILG gets the length of the data block opened with OPN DIxx
Thanks for the info LD.
Cheers ;)
hi,i'm an undergrad student frm india exposed to a KOYO plc for the first time.i basically joined the forum for some tips to program the...
3,363
Hello let me explain my problem. I just got tossed into a somewhat complicated job because the person that normally does the writing is on...
3,837
Hi. I tried to find help in for documenting or migrating Pilz Pitouch HMI projects (in 2007) in this thread...
1,507
Hi all. I am trying to find safety application examples for an inspection door with electromechanical interlock. I can find many door switches...
39
13,723
118
