Detect On Top Display Number FTVW ME
Dirtleg
Dec 2014
Virginia
25
Hello all I have a program for a Panelview Plus6 1000 that I am pretty much done with but was wondering if there was a way to detect whether or not an On Top display is open and if so the display number.
My reasoning is that I'm using a multilevel permissions user/password database hosted in the PLC. This is a home grown bit of logic and everything about it works fine with one exception.
I am using an On Top display for the user name and password data entry. Once the correct password is detected I close the on top display and set the commanded display to the screen I want it to go to. But, if the user is already logged in and exits out to the main area when they try to go back to the protected area they get stuck with the login screen again.
I want to bypass the login screen if the user is already logged in. The simplest way to do this would be to detect if the login screen was being opened. But unfortunately I do not know how, or if it's even possible to detect when an On Top display is open.
I have it working now by making the Display Type "Replace" instead of "On Top" but would prefer the "Pop-Up" screen as it better suits the flow of the rest of the panelview program.
In Global Connections under the display tab I am using Replace Display Number as my actual screen detection, Remote display number as the commanded screen from the PLC, and Close an On Top Display to close screens.
So any thoughts?
Thanks.
As far as I know, there's no way to detect an on top display in the same way that you detect a replace display.
I'd approach it by setting the on top display to run a macro at start up, and another at shut down. Your macro could just set/reset one bit to say "login screen opened/closed", or if you want to try and mimic something like the replace display number global connection, you could have it set an integer to the number of the display. You'd have to code the number of the display manually of course, there's no way that I know of to tell a macro to write the display number itself.
Hello, I am trying to detect when the PLC changes from STOP to START mode. This can be considered an edge case scenario, but I would to analyze...
1,570
Hi; How can i detect that PLC in stop mode. Becuase there are some options which can be happen: 1. If operator stop the PLC by pressing ALT--R...
3,844
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Hi all, I am trying to find a way of detecting a motor is not isolated before attempting to run an inverter. We would normally use a 4 pole...
19
3,085
Hello everybody, I have a vendor system that has some remote monitoring (read only) and remote control (read/write) data that is available via...
2,876
