Detecting PowerFlex 525 Ethernet Comms Fault
papacroft
Apr 2020
Huddersfield
I'd like to be able to detect if the Ethernet Comms falls over between my PLC Ethernet card and any of the 5 PF525 inverters I have connected to it.
There's some data types - module defined members e.g Faulted, Ready, Active etc. There's one call CommFreqCnt, but not sure what that's for. Any advice much appreciated on a way to detect falling over.
(Background: The Ethernet card is 1756-ENBT/A connected to a managed cisco switch which connects to an unmanaged switch which has the 5 inverters.
Basically after improving robustness, so that I can issue a shutdown of system if I have a comms failure to an inverter...
Thanks in advance.
There's a whole reference manual about doing network connection diagnostics in the Logix controller family, but fortunately this is fairly straightforward.
https://literature.rockwellautomation.com/idc/groups/literature/documents/pm/1756-pm015_-en-p.pdf
You will use the Get System Variable (GSV) instruction to read the EntryStatus value of the Module object for each PowerFlex that's in the I/O tree.
The highest 4 bits in the 16-bit INT that you get back from that instruction represents the status of the connection. When the value = 4, then connection is established and running. Any other value, it's broken or un-established, or resetting.
What I do is run the GSV every few hundred milliseconds, putting the Module/EntryStatus value into a tag I name "ThisDrive_EntryStatus_Raw".
Then I divide ThisDrive_EntryStatus_Raw by 4096 to shift the value 12 bits to the right, putting the result in ThisDrive_EntryStatus_Value (a DINT type tag).
Then I just evaluate whether ThisDrive_EntryStatus_Value = 4, and turn on a "Connection_Status" BOOL.
Thanks Ken,
Out of curiosity. Why do we need to take the entry status? Is there a difference if we the attribute fault code like attached.
The fault flag will set high on a 525 when a net loss occurs. That is only IF it had a valid connection first, then lost comms. If the drive never connects after power up then the net fault loss will not be detected.
If the system is small enough I just use a GSV for the IO status instead of looking for status of each drive.
Interesting, I never knew that. I guess the fault bit isn't very helpful for comms loss then since you don't know if it's a comms loss or an actual fault, if you get the fault bit at all.
I've always used this. Is that the incorrect way of going about it?
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/552012
Hello all. I am currently using a compactlogix L36ERM to control 5 Powerflex 525 Drives over Ethernet. The problem I am having is determining...
4,211
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,305
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,146
Hello everybody, I am working on a project which has HMI FTView SE 13 (Local) and controllogix L71 PLC. I have a question how does PLC detect a...
516
So, we have one servovalve that is very critical to machine operation and idea is (or was) to detect if valve gets disconnected from analog output...
2,915
