Determining global IP address of compactlogix and panelview
Paul_Pereira
Jan 2023
Amsterdam
51
I have my PLC and HMI connected to my local network over DHCP just like my laptop. I can upload and download including VNC to the HMI over wifi from my laptop. I would like to work on the machines remotely as well if I need to travel. For this I believe I need to use linx gateway. How do I set it up?
You'll need some sort of VNC server on the external connection when you are remote. I don't think you'll need to do anything specific to get a VNC through RS Linx, it should be able to browse. I'd strongly recommend not using DHCP on the internal network, unless there's some overriding reason.
You do not need RSLinx Classic Gateway or FactoryTalk Linx Gateway. Both of those are special-purpose software that bridges communication driver configurations like DH+ and serial or OPC and FT Live Data, rather than general purpose network devices.
In general, you need a VPN or other general purpose network bridge to allow access to the network to which your machines are connected.
Part of configuring your PLC and HMI will also be setting the "default gateway", which will be the local network IP address of whatever router or VPN appliance you use. If you have a DHCP server, it may already be giving the devices its own IP address as their default gateway.
We are in the process of installing a new DC drive to replace a 1373 series Speedpak drive. There are 8 leads coming out of the motor -- Two for...
847
Good morning! I am looking for a clever method to determine the number of occurrences in a series using ladder logic. What I need to determine is...
1,261
We have a DC Drive (ABB DCS800) which is running a load (initially) at a fixed speed. For testing purposes, we want to simulate a different...
20
6,288
ive been tasked, due to a restructure of our inventory, to find out how big our SLC programs are. specifically, we have several dozen 5/05s at...
1,719
I'm programming a AB 1769-L18ER processor with Studio 5000. I'm wondering if anyone knows away to determine how many inputs are on thru logic...
2,414
