Hi Is my first time I post in this forum and also Im new in all this things of PLC programming so I hope someone can help me with this problem.
Im trying to connect a PanelView Plus to an existing devicenet network with a SLC 05 and the 1747-SDN scanner module and the problem is that when I try to detect the PanelView the RS Network dont see it, it detect the other nodes that were already in the network but not the node of the PanelView.
The PanelView has the 2711P-RN10H module for devicenet. I already did all the configuration according to the manual for the devicenet module of the panelview, slot 0 for the virtual backplane and slot 1 for the module, the speed is 125 (I also try with the other speeds just in case) but the RS Network dont seem to detect it, I try with other 2711p-RN10H to see if the error was from the module but nothing change, in the module the MOD led indicator just start to blink but the other leds (net and I/O) are off.
I dont know what is the problem, if is the scanner, or if there is a special configuration or something I dont know is driving me crazy I would appreciate A LOT if someone can help me
Thank You
sorry if my grammar is not so good
A. Perea
Thank You
A. Perea
