DeviceNet Mapping issue
angi
Jan 2010
us
361
Hi Guys
There is a tester on my floor, using SoftLogix, 1784-PCID interface, 1734-ADN Adapter and 1734-IB2. when I open the PLC program, the data from DeviceNet is N50:aa/bb, I could understand how the aa/bb been set, but I could not figure out how the designer set up the memory as N50. I know that we could use M1 or M0 as memory for SLC500.
Any body could help me to figure it out?
Is this a SoftLogix 5 ?
If so, go to the controller's Status file in RSLogix 5, then tab to the right until you find the DeviceNet Tab.
The data file numbers for the Input, Output, and Status files are configured by placing data file numbers into Status file elements S:509, S:510, and S:511.
RSNetworx for DeviceNet software just calls these data files the "Image File", and you designate the word offset to start mapping data into.
I have to modify a device net network by adding two nodes(VFDs) to the network.Please advice me how i can map input and output to PLC...
1,680
Hey All, Looking for some direction on how to map a SMC EX250-SDN1 SI unit to an Omron CJ1W-DRM21 device net scanner. The manual says that it...
3,108
Hi, I have a Devicenet scanner and its various data i.e. addresses. How to I read these using my SLC500 PLC?
1,669
All, We are using DeviceNet for remote I/O modules. I have configured an alia tag for each digital input and output. For Example: TYPE TAG...
2,296
When the input and output areas of my devicenet scanner are mapped to my E3 overload relays, the 4 input assembly words are mapped to 2 x 32 bit...
3,574
