DF1 Half Duplex Comms
jgreenewv
Aug 2002
New Mexico, USA
242
I'm working on some system mods for a customer using three SLC 5/04s. It would be handy to have all three as DF1 Half Duplex masters, so I can have one PLC poll the other two, then have the two "slave" 5/04s poll MicroLogix1000 that will be added later. I don't have the hardware in front of me right now to try it. Has anyone done this? Thanks for your input.
DF1 protocol doesn't work like that. The right way to do this is to have one SLC-5/04 as DF1 Half-Duplex Master poll all four controllers as DF1 Half-Duplex Slaves.
The slaves (at least the 5/04's, I'm not sure about the Micro 1000's) can message to one another (the master brokers this) but a device cannot both be a master and a slave on a DF1 Half-Duplex network.
That's what I was thought. The problem is that the two Micro 1000s in the example are unable to communicate directly to the master SLC due to terrain. Back to the drawing board.
I have read the Scada Works book and I was wondering if anyone has any kind of sample programming for this type of setup. Allen Bradley Master=slc...
2,376
I am trying to design a system to replace an OEM 1980's control for auto setup order recall with 30 axis. I will reuse existing encoders 25ppr...
2,465
Gentlemen, I am the "radio guy" that occasionally runs into PLC challenges as follows: My customer/integrator has found that the radios he is...
2,605
Hi, I have a micrologix 1100 series B, the serial port is connected to a Panelview Component and configured as DF1 Half Duplex Slave. I would...
2,786
Hi All, One of my project is using SLC500, the Serial port on CPU is configured as DF1 Half Duplex Slave, is it possible for the host(cygnet)...
2,157
