DF1 Half Duplex with Radio Modems
kkgo
Nov 2002
I have configured a SLC5/04 as a DF1 Half Duplex Master polling a MicroLogix1000 slave. Using the option ""Half Duplex without Continuos Carrier"
I tested it out using a direct cable, with RTS and CTS shorted together and it seems to work fine. I did a MSG Write and MSG Read.
When I plug in the radio modems, something funny happened. The MicroLogix1000 seems to "see" the message Write from the Master and switched on some corresponding points as per my logic, but the master thinks that the slave is not responding.
On further probing, I found that the reply from the slave to the master (I think it's "ACK" since the MicroLogix1000 did execute the logic correctly) did not get through. I found this out by testing each control line between the Master PLC and the radio modem.
Has anyone come across similar situation before?
I am using a TAIT T2000/2 Series II radio modem (1200/2400 bps)
I have read the Scada Works book and I was wondering if anyone has any kind of sample programming for this type of setup. Allen Bradley Master=slc...
2,375
I am trying to design a system to replace an OEM 1980's control for auto setup order recall with 30 axis. I will reuse existing encoders 25ppr...
2,465
Gentlemen, I am the "radio guy" that occasionally runs into PLC challenges as follows: My customer/integrator has found that the radios he is...
2,603
Hi, I have a micrologix 1100 series B, the serial port is connected to a Panelview Component and configured as DF1 Half Duplex Slave. I would...
2,785
Hi All, One of my project is using SLC500, the Serial port on CPU is configured as DF1 Half Duplex Slave, is it possible for the host(cygnet)...
2,157
