DF1 Half Duplex
gherz817
Oct 2005
PHILIPPINES
58
Hi everybody!
Somebody could help me on how to configure SLC 5/04 with a DF1 Half Duplex configuration? Any input would be much helpfull to me..
Thank You Guys..
This is under RSLinx
you can search there are many thread on this....I think mrplc.com has a good procedure, are you just looking to communicate? or do data transfer?
GIT
I read his question a little differently:
Go to channel Configuration, then Channel 0
The Channel can be Half Duplex Master depending on which series you have.
Thanks guys, when i configured in RSLinx it doesn't work as it. It says that check all cables and configuration settings via autoconfiguration button.
If you set the channel configration in your SLC as Mickey explained DF1 Half duplex slave then use the DF1 Polling MAster driver in RSlinx
Do you have the offline file (.RSS) for your SLC5/04 if you can post it.
With it we can see your channel configuration and help you get online.
I have read the Scada Works book and I was wondering if anyone has any kind of sample programming for this type of setup. Allen Bradley Master=slc...
2,376
I am trying to design a system to replace an OEM 1980's control for auto setup order recall with 30 axis. I will reuse existing encoders 25ppr...
2,465
Gentlemen, I am the "radio guy" that occasionally runs into PLC challenges as follows: My customer/integrator has found that the radios he is...
2,605
Hi, I have a micrologix 1100 series B, the serial port is connected to a Panelview Component and configured as DF1 Half Duplex Slave. I would...
2,786
Hi All, One of my project is using SLC500, the Serial port on CPU is configured as DF1 Half Duplex Slave, is it possible for the host(cygnet)...
2,157
