DF1 Protocol
YoungWint
Dec 2012
East Midlands
77
Guys/ Gals
Have an application where I am using DF1 protocol on a compactlogix to communicate with a radio device.
The plan is to read date (no write) from the PLC to a SCADA/ RTs system via the radio link.
From the users manual I have set my comm port as recommended and set up three arrays of 255 (2 x Integer, 1 x Real). These have all been declared a PLC5/ SLC for data mapping.
The interface to the Radio link is a hardwired DF1 with, I believe the transmitter set accordingly. The gap in my knowledge, and information, is if I need to write my data using MSG to the radio link or not !! Or as would seem logical the SCADA system drills in and retrieves its data from the specified files.
SCADA and the actual Radio Link is being done by a third party with the radio system being Churchill (new system to myself).
At this stage any advice or knowledge would be greatly appreciated.
Cheers
Young Wint
In general, SCADA systems initiate requests to remote controllers (like your CompactLogix) and you don't need to program a MSG instruction to transfer that data.
One detail that frequently comes up is the error checking mechanism; if Churchill designed their software around the SLC/MicroLogix family they will have used CRC error checking, while the default for the ControlLogix and CompactLogix is BCC error checking. All you have to do is change that setting in the CompactLogix port configuration.
I have to load a project to a PLC 5 processor via DF1 protocol. I have a laptop with a PCMK card in it with the 1784-PCM5/B Cable. I have to...
2,354
I am looking for a way to view/edit the program in a SLC 5/02. Currently I am using the 1747-UIC to do this but I would like to be able to do this...
2,602
Currently I test the communication with AB SLC500/04 using DF1 protocol.I find that the communication is ok when CPU is in program mode .while I...
2,686
So i have brand new control logix and everything.so i i am gonna flash the processor first right ? I have installed rsl5k in vmware . As the...
3,114
We have a runtime file for a Panelview that's set up for DF1 communication protocol. We want to change it to communicate with the same PLC...
3,414
