Vmware and df1 protocol
aradhonline
Nov 2009
Dubai
62
So i have brand new control logix and everything.so i i am gonna flash the processor first right ? I have installed rsl5k in vmware . As the network is controlent and i have nor ent module i am going for df1 .but inside the vmware i am not able to detect the hardware . But in my host machine it is availabel and able to detect ?.i have stopped the rslinks in host and tried in vmware .but that also in vain.
Any soulution u guys ..i know there is people out there who is expert in vmware .
Make sure that the Serial Port hardware has been added to the VMware machine settings.
Make sure "Connect at power on" is checked. If you are using a computer with two real serial port then specify which COM port the VM should use. If only one real serial port, then auto-detect should be ok.
If you are using a USB/RS232 adapter then adding this Serial port setting is not necessary. But you absolutely MUST identify within the VM what COM port it is using. On my machine my USB adapter pops up as COM7. You can do into your Windows Device Manager to locate this setting.
OG
Oh that is amazing Mr OG .You made the solution in just 1 and half an hour. My flashing is going on at this time ...You should change your name to Ohh My God (OMG) ..
Thanks dude.
Greetings all. I am having a new problem with my VM. Host OS is 11 and VM OS is 10. I have two smaller monitors that connect to my laptop which...
583
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,057
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,634
Hello Hivemind My wife has a legacy machine at her work which uses (or I should used) an XP desktop with a serial port to communicate with a...
1,089
I have a MacBook running Monterey. I have a VMWare Fusion virtual machine on it running Win10. On the VM I have the Rockwell toolkit loaded. I...
3,051
