eight_bools
This has been on my mind for a while now, wondering if anyone here has any best practices or insights. I have been working with a plant that has a pretty large DH+ network that causes them a lot of issues. It looks like the network was designed initially as a small packaging line, all communicating nicely. Over time it was expanded, I don’t have an exact node count in front of me but I think it’s close to 30.
To me it doesn’t make sense that it is as large as it is, and that it’s not separated into smaller sub networks of equipment that needs communications. It covers 3 production lines and some common support equipment. I also saw that there are some circular connections (both a & b channels connected on a DHRIO bridge)
Before I can help them put a plan together to move forward I would like to map the physical layout of the network to get an idea of what we are looking at. I have some software called NetDecoder to get an idea of which machines are communicating with each other. That should help me get a list of all the msg instructions that are being used. I am at a loss though of a good way to trace the actual cables.
The only thing I can think of is to unplug all the connections while they are down, and use a cable tracer on each of the connections. This makes me nervous, I would hate to miss a controller and fry the comm port. It seems less than ideal, it is a large facility and it seems like an exercise like this could be quite time consuming.
Anyone ever done something like this or have any suggestions?
