DH+ Network
angi
Jan 2010
us
361
Hi Guys
There are 7 SLC5/04 on the floor, I am going to set up DH+ network using Daisy Chain configuration, and then connect to Ethernet and Wireless, so we could manage and config all of the PLCs remotly.
My question is whether it is necessary to buy the DH+ Network cable from AB?
You should be able to buy from Belden (the cable manufacturer) depending on their agreement with AB in your area.
Note: dont try and use any other type of 2 core screened cable, i have had to fault find these type's of installations on more than 1 occasion and the customer always has to end up ripping it out and replacing with correct cable
HI angi. Here is the cable number#.
BELDEN 9463 BLUE HOSE P-7K-SC-182006-2-MSHA 1PR20 SHIELED (UL) E34972 CM OR CL2 OR AWM 2464 OR C(UL) CM--- ALLEN BRADLEY CAT# 1770-CD -40C 2KA
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
445
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
288
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
224
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
73
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
960
