Steve4141
I am trying to set up point to point communications between a SLC 5/03 and a Panelview 600 touchscreen 2711-T6C5L1. I'm using the RS232 port on the panelview, A 2711-NC13 cable to channel 0 on the 5/03. The panelview is setup for DH485, Baud rate is 19200, Node address is 2. The 5/03 channel 0 configuration is set node address 2, baud rate 19200, and driver is DH485. Channel 1 configuration is set for node address 1, baud rate 19200 and driver is DH485.
RS Linx driver is 1747 PIC, comm port 1, station number 0, baud rate 19200. RS Linx is able to see the 5/03 but not the panelview. The panelview is dispalying a message "No active nodes found on network"
Can anyone tell me what I'm doing wrong and what I need to do to establish communication. Any help would be greatly appreciated.
