Diagnosing ethernet-based fieldbuses.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Hi all.
We are slowly moving away from Profibus towards Profinet.
What I worry about now, is how to diagnose basic hardware faults with Profinet.
With Profinet Topology we can have a detailed error diagnosis telling us that there is a problem with a specific module or port on a module. But how to pinpoint problems relating to noise, earthing, bad cables, etc.
With Profibus we have had our share of problems, and a profibus tester has helped us on occasion. Like this one:
http://www.procentec.com/profitrace2/
Does something similar exist for ethernet/Profinet ?
What do people do ?
I'm partial to my Fluke NetTool Network Tester. Expensive. Portable. Very easy to understand and run: can learn it in just a few minutes. Has TDR to diagnose breaks in wires. Has easy-to-understand diagnosis and display of network activity. Can be placed directly in-line with a 'hot' circuit or used to test new, not-yet-lit-up wires. I've run many miles of CAT5E and this has been invaluable in verifying every wire to full gigabit standards.
You'll find a number of Wireshark fans on this website too. Free. Just runs as an app on your laptop.
Thanks nwboson, what does 'expensive' mean ? Just an approximate price.
Thanks Peter, but I am not after analysing the packets. I expect the diagnostics that is integrated into Profinet to pinpoint problems like that for me automatically.
I want to test the cables themselves, if there are grounding problems, if there is noise, stuff like that.
I've picked up a Series 6+ PLC (and a lot of cards) recently and am trying to get the unit running, however when I install a CCM into the unit, it...
3,030
Hello Everybody. As a part of my job I try to diagnose various industrial wireless systems. 90 percent are leaky wave or so called radiating...
2,869
I'm new here. I'll make this, hopefully, as clear and concise as possible. I am using a s7-200 siemens plc cpu type 224xp with the em232 analog...
3,173
Hi, need som advice regarding setup diagnosing IO devices for profinet. System: IM151-8 siemens plc IO´s Wago 750-370 profinet. Problem: Need...
2,171
Hi. I have seen some instructions for diagnosing DH+ with a scope. And I have heard that it should also be possible with Profibus. Does anyone...
23
10,848
