Diagnosing Series 6+ CCM/CPU Communications Fault
Sukasa
Sep 2014
Nanaimo
I've picked up a Series 6+ PLC (and a lot of cards) recently and am trying to get the unit running, however when I install a CCM into the unit, it repeatedly reports that it cannot communicate with the CPU and shuts down. I don't have access to (nor could I afford) a WorkMaster, or WASI card in order to communicate with the PLC over the DB37 connection.
After a lot of searching I haven't been able to find many answers as to why neither of my CCM (type 2) cards can apparently communicate with the onboard CPU.
The CPU itself has failed parity on the memory board, as the battery had run out before I got it. The sum total of the lights are:
Memory Board (16k logic + 8k register): BATTERY on, PARITY off.
Arithmetic Control Board: RUN off, CHECK on
IO Control: CHAIN OK on, CHAIN PARITY on, ENABLED off, DPU on (set for no DPU)
CCM: BOARD OK off. Diagnostic code is 'CCM/CPU Communications fail'.
What could I do to find the problem preventing my CCM card(s) from communicating with the CPU, and how could I go about fixing them?
The CCM card must go in slot 5 which is the one just to the left of the memory module or slot 6 which is to the left of slot 5. If installed in slot 6 all backplane dipswitches need to be in the open position. Try removing/reseating all cards using the removal/insertion tool to get the cards seated as firmly as possible.
Oh, I forgot to mention that the POWER light on the PSU is on, and when I checked it with an oscilloscope, all the power rails are steady with no noise.
I'll try seating the card in slot six, leaving slot 5 empty. I've reseated all the cards a few times, as well as cleaned the cards and the backplane (it was covered in a large amount of sawdust prior to being cleaned)
Okay, I found the problem - many thanks to you!
Turns out, the DIP switches on that slot were all closed, rather than all open - the manuals I have did not list anything about needing to be all open. That's gotten the CCM working properly - all the diagnostic lights are on and the CPU's CHECK light stays lit.
At this point, I guess I just need to figure out where I can get a copy of the serial version of LogicMaster 6.
Hello Everybody. As a part of my job I try to diagnose various industrial wireless systems. 90 percent are leaky wave or so called radiating...
2,861
I'm new here. I'll make this, hopefully, as clear and concise as possible. I am using a s7-200 siemens plc cpu type 224xp with the em232 analog...
3,172
Hi all. We are slowly moving away from Profibus towards Profinet. What I worry about now, is how to diagnose basic hardware faults with Profinet...
1,938
Hi, need som advice regarding setup diagnosing IO devices for profinet. System: IM151-8 siemens plc IO´s Wago 750-370 profinet. Problem: Need...
2,171
Hi. I have seen some instructions for diagnosing DH+ with a scope. And I have heard that it should also be possible with Profibus. Does anyone...
23
10,829
