Differance between actual and set point speed
gh_ounie
Dec 2007
aleppo
73
We have problem in our Siemins drive SIMOVERT MV type number 6SE8001 when we look the actual speed we find it more than setpoint speed and the gap between the actual speed and setpoint speed become less when inverter is running in low speed and become more in high speed .o_O
If you have any idia about problem let me know.
With best regard
Since you are referencing speed rather than frequency, I conclude that you are in closed loop or vector control.
If that is the case, I would display the drive frequency and compare that to the measured shaft speed using the motor nameplate data. From that, you should be able to determine if the motor is motoring (negative slip) or is being pushed into regeneration (positive slip). If your speed loop tuning is really loose, you might just find positive slip giving you more speed than setpoint.
V
I want to know the differance between AC and DC servocontrol motors as well as Drives. Also I want a comparison with normal motors.
5,058
vnkarwa
V
I am a little new to Devicenet and I have to get a robot station up and running. The current Devicenet cables in the station are all 4 pin. The...
5,332
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
42
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
34
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
93
