jfd7851
I haven't had an opportunity to use the 1734-8CFG, but have seen it in different resources from Rockwell. I have used the 1734-VTM before when wiring sensors with the 1734-IF4U Analog Input Module. I understand that the 1734-8CFG is a 24VDC source out/sink in I/O. I am confused on the difference between the two and when you should use either one. I think most of my confusion is lies because I haven't actually had to use the 1734-8CFG. I am mostly just curious for future reference.
Thanks in advance!
Thanks in advance!
