Difference Between a Transistor PLC & a Relay PLC
Towerlight
Mar 2007
NYP
24
Hi...can anyone share with me what is the difference between a Transistor PLC & a Relay PLC? As I only uses a Transistor PLC i do not know much about a Relay PLC.
Thanks for viewing anyway.
Cheers ;)
A transistor output is a solid state device, and is usually only capable of switching low current DC, most often 24 VDC. They are capable of very fast operation.
A relay output has a physical relay on the output board, and the switching is done by physical contacts that open and close. They can switch AC or DC and higher voltages - usually up to 230 VAC.
Which you choose depends on the device that the output is switching.
Also, the expected contact life on the relay can be an issue if you are designing a low cycle time machine(few seconds per cycle). Where as transistor or other solid state outputs usually have a much longer life span. Just look at the PLC output card specifications for details.
I usually use relays because of the flexibility among voltages, only a few times I have used solid state outputs mostly due to the expected lifetimes.
I am trying to understand the difference between transistor and relay plcs. When do you use one over the other?. I have tried to research about...
3,147
D
Can someone explain to me the difference between a relay output and a transistor output? I'm working with Keyence KV 24AR or KV24AT (Relay or...
24,874
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,415
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,046
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,973
