Kyle Sleiman
whether time counts down or up it makes no difference,
when time elapse the done bit state in any plc will be changed to high.
unless you are using a comparator instruction to create a sequence based on timer CV value (inaccurate system, unless you use interrupt events) then I don't think you should concern your self of how a timer times out.
having said that, can't you write a one rung code and debug online in your S7 software to see if the CV of the timer is going up or down ?
Kind regards.
Kyle Sleiman
Kind regards.
Kyle Sleiman
