Different IP Address
vel.s
Oct 2009
pune
Hi everybody,
This is the common problem that each and every programmer facing with their PG.
Normally we will have to connect to the different ethernet devices with different IP addresses.
Is there any Free software so that we can configure once all the IP addresses and can select the PG IP through the software single click instead of all times going to the lan settings and changing the IP which is long tidious process
I've used both the "multihoming" method shown near the bottom of Mickey's link, and the "Alternate Private IP" Address, but ultimately just ended up with two NIC cards.
This is probably obvious advice, but if you use a laptop with a dock, plug the USB to Ethernet jack into the dock and connect that to your company network, and set up the built-in NIC to the IPs needed for the factory floor, that way when you take your laptop onto the factory floor you don't have to carry extra hardware.
I have the same problems as the OP.I have a wireless router and some bridges for connecting to equipment when troubleshooting. I wanted to know if you could use the router and make a routing table to pass data to all the different networks?
I have two batch files I use. If they are of interest to you, edit them as needed and save them with the extension BAT.
Restore DHCP:
@echo off
@path=C:\Windows\System32\;C:\Windows\System32\WBEM
@netsh interface ip set address "Local Area Connection" dhcp
Set IP to 192.168.1.199:
@echo off
@netsh interface ip set address name="Local Area Connection" static 192.168.1.199 255.255.255.0 192.168.1.1 1
150
Why is the configuration IP different from the actual IP address still able to run normally?
838
I was recently browsing the print out of our network sheet with different IP address. One portion of our plant(section A) which has controllogix...
4,400
I'm trying to do a message instruction from ControlLogix you see on the left to the CompactLogix to the right. I'm losing this battle. I've tried...
4,044
Hi guys I have 2 machines with Allen Bradley plc one is compactlogix and the other is a mircologix all on Ethernet, I would like to commuicate...
4,263
