different speed selection for PF700
angi
Jan 2010
us
361
Hi guys
the PF700 we are using always run at the same speed(Preset speed1), I want ot run different speed at different time, for example, Preset speed2 for 10s and preset speed1 for 20s, and there is only one digital input left for me to use.
how to make it happen?
I am using 3 wire control.
Digital in1 for start, in2 for stop, in3 for CCW, in4 for Acc selection and in5 for Enable. only in6 we could use. how to change the speed ref selection?
You can switch to two wire control and free up one more input. Then you can get 4 preset speeds total.
To get something your going to have to give something up. It is what it is.
Angi,
I don't have a PF700 manual handy, but I imagine you could set the drive up so that DI6 is your speed select input and that DI6 ON=Speed 1 and DI6 OFF=Speed 2.
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
131
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
175
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
96
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
171
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
419
